Sponsored by: CARiD
Disco 1 California Smog issue HELP !
Old Jun 25, 2012 | 01:22 AM
Docbrit's Avatar
4th Gear
Default California Smog issues update.
Hi Guys.
Ok so here we are, a smog retest in the morning, It took me some time due to working 12+ hour shifts but we now have :-
New cap rotor and wires.
8 New Bosch spark plugs
Fresh Fuel with Octane booster.
Wife booked to take it in tomorrow morning!
If it fails, it looks like new sensors and cats?
Hmmm I need it to pass !
Further updates coming soon.
Thanks
John
Old Jun 26, 2012 | 06:57 AM
Docbrit's Avatar
4th Gear
Hi Guys
So after the Cap, Rotor, Plugs and wires etc The re-test went as follows:-
Co increased to 0.28 Still a good pass!
HC Dropped from 143 to 131. Still no good and FAIL !
Ok; back to the drawing board.
Quote for new Cats.. No sensors. $297 Ea without Tax So basically Im in for another $650 or so.
before i commit to that, any more ideas Guys ????????????
Thanks
John
Old Jun 26, 2012 | 10:15 AM
Scharfire's Avatar
What plugs are you running? Also drop your oil and filter then put in a quarter tank of fuel and run a few bottles of ethenal in the tank. That ethenal will burn hotter and take out those carbons. You shouldn't need cats or o2 sensors if it's not throwing codes. I bet your truck has some miles like the rest of us. The ethenal treatment will do wonders to pass your truck. Make sure your running copper plugs. Ngk's seem to be the best. It just sounds like you have a carbon build up that you need to burn out.
After changing the oil fill up to a 1/4 tank put in the ethenal drive in a hilly area to put a load on the truck. Drive about 50 miles then take it to the smog shop DO NoT turn it off. Ask to smog and you should pass.
Old Jun 26, 2012 | 07:32 PM
Those cats are over priced, you can have universals welded in for like $150 each.
Old Jun 27, 2012 | 10:11 AM
wheelgarage's Avatar
Do the universals....if you can find a shop to do it. Most of the shops around CA have the Magnaflow ones and an alternative. It does sound more of your cats not burning off unspent fuel. Have you pulled off the y-pipe to see the condition of them?
I had a spec Miata awhile back. Before I made any upgrades, it was up for smog. It passed, but was on the borderline of passing, high HC's....glad as usual. Weeks later, I pulled off the entire exhaust system. I found that the CAT had a big gaping hole in the center of the brick.....I always wondered how long it was like that....and wonder how the heck it passed?!?!?! From experience, it looked like the PO used a heavy amount of some type of fuel cleaner.....
tcjx4
Mar 3, 2013 03:22 PM
disco118
Dec 23, 2011 07:39 AM
Carl082974
Aug 16, 2010 11:44 AM
sfxgamer
Aug 17, 2007 09:05 AM
evoasis
Nov 17, 2006 10:31 PM
