Disco 2 - AC codes 21/22
I tested a recently purchased truck and my AC codes are 21/22. How do I replace the Sun sensors?
Will the AC function without it. I tried lowering the temp to LO and still could not get the snow flake. It is cold outside and was hoping its just EXT temp not letting the AC run.
I posted this on another LR forum so hopefully this will help you...
“I searched the forum to see if I can piggy back on someone else's Disco II posts about air conditioner fault codes. I couldn't find any so I'm posting here for future reference to help others.
I completed the air con diagnostics check on my 2001 Disco SE by following these steps from this video
1 - Turn ignition OFF.
2 - On the climate control panel, press and hold both AUTO and Air Distribution buttons.
3 - While holding these buttons down, switch ignition ON to position 2.
4 - Keep holding the buttons for 4-5 beeps and let go. The fault code (FC) results will be shown on the right side of the screen.
After doing this check I had two fault codes that popped up on the screen; 21 & 22.
I did a Google search and found a list of the fault code descriptions:
00 - no faults
11 - in car temp sensor fault
12 - ambient sensor fault
13 - thermistor fault
14 - heater coolant sensor fault
*21 - left sunlight sensor fault - open or shorted
*22 - right sunlight sensor fault - open or shorted
31 - left servo motor
32 - right servo motor
33 - distribution servo motor
I did another Google search about the 21 & 22 errors and found the answer on an Australian LR forum. Someone stated that you will get fault codes 21 & 22 if you don't do the test in direct sunlight. It made sense since I did the diagnostics check in darkness of my garage.
After reading this, I pulled my Disco out of the garage, let it sit in the Georgia sun for an hour, redid the check and BAM! I got the no fault code of 00!
I hope this helps others! Cheers!”
00 - no faults
Tried the defrost and still warm air
21 & 22 come up if you do not do the test in direct sunlight. In other words, pull the truck out of the garage on a sunny day and rerun the test
if the ac is not working, see if the system needs to be charged
luxury1
Jan 29, 2008 10:14 PM
GodSavetheQueen
Jan 9, 2008 12:15 PM
