Sponsored by: CARiD
Disco 2 - AC codes 21/22
Old Apr 13, 2019 | 08:52 AM
Steve Selyutin's Avatar
4th Gear
Default Disco 2 - AC codes 21/22
I tested a recently purchased truck and my AC codes are 21/22. How do I replace the Sun sensors?
Will the AC function without it. I tried lowering the temp to LO and still could not get the snow flake. It is cold outside and was hoping its just EXT temp not letting the AC run.
Old Apr 14, 2019 | 01:11 AM
JUKE179r's Avatar
I posted this on another LR forum so hopefully this will help you...
“I searched the forum to see if I can piggy back on someone else's Disco II posts about air conditioner fault codes. I couldn't find any so I'm posting here for future reference to help others.
I completed the air con diagnostics check on my 2001 Disco SE by following these steps from this video
1 - Turn ignition OFF.
2 - On the climate control panel, press and hold both AUTO and Air Distribution buttons.
3 - While holding these buttons down, switch ignition ON to position 2.
4 - Keep holding the buttons for 4-5 beeps and let go. The fault code (FC) results will be shown on the right side of the screen.
After doing this check I had two fault codes that popped up on the screen; 21 & 22.
I did a Google search and found a list of the fault code descriptions:
00 - no faults
11 - in car temp sensor fault
12 - ambient sensor fault
13 - thermistor fault
14 - heater coolant sensor fault
*21 - left sunlight sensor fault - open or shorted
*22 - right sunlight sensor fault - open or shorted
31 - left servo motor
32 - right servo motor
33 - distribution servo motor
I did another Google search about the 21 & 22 errors and found the answer on an Australian LR forum. Someone stated that you will get fault codes 21 & 22 if you don't do the test in direct sunlight. It made sense since I did the diagnostics check in darkness of my garage.
After reading this, I pulled my Disco out of the garage, let it sit in the Georgia sun for an hour, redid the check and BAM! I got the no fault code of 00!
I hope this helps others! Cheers!”
Old Apr 14, 2019 | 01:45 AM
4th Gear
Default AC - should there be a snow flake?
So the code cleared doing the test in the sun. I still don’t hear the AC clutch engaging nor do I see a snow flake on the display.
Old Apr 14, 2019 | 06:43 AM
mollusc's Avatar
i don't think there is a snowflake to show.
have you tried turning on the windscreen defroster? that should force the a/c to come on since it acts as a dehumidifier.
Old Apr 14, 2019 | 11:41 AM
4th Gear
Tried the defrost and still warm air
Old Apr 14, 2019 | 08:37 PM
Friday Night Disco's Avatar
21 & 22 come up if you do not do the test in direct sunlight. In other words, pull the truck out of the garage on a sunny day and rerun the test
if the ac is not working, see if the system needs to be charged
okdiscoguy
Jan 16, 2024 04:31 PM
JUKE179r
Build Threads
169
Dec 29, 2023 05:49 AM
Chesley
Jun 28, 2019 11:34 PM
luxury1
Jan 29, 2008 10:14 PM
GodSavetheQueen
Jan 9, 2008 12:15 PM
