Disco II - Electrical problem
Hi all. I have a problem with my Discovery II, 02 model. Every time I try to adjust the electric wing mirrors, it blowsthe 20Afuse???!! [&o]The cruise control and rear washer unit are also on the same fuse - both of which work fine until you try to adjust the mirrors... kabang! another dead fuse. It got to the point where the mirror adj. switch didn't work anymore at all, despite changing the fuses numerous times. I replaced the switch... worked fine for ca. 1/2 an hour...then, gues what? the fuse blew [:@] I wonder if anyone else has had this problem and could shed some light on it for me. I could really use the help. Many thanks. Chris.
