Sponsored by: CARiD
Snapping Thud When Engaging Drive & Reverse
Old Dec 15, 2007 | 07:56 PM
philo73's Avatar
Default Snapping Thud When Engaging Drive & Reverse
Hi Guys,
I just hit 100,000 miles on my '99 Disco II. Within in the last couple weeks I've had an alternator and air suspension go bad. The car has just developed a new problem. I've noticed a pretty loud thud when engaging D or R. Once the car is off and running I have no vibration or anything like that. I had a friend engage the gears while stopped, and noticed the front drive shaft turn a couple degrees and then make a Snap sound...as my friend put the gear into R or D. It does it from R to D and vice versa.
Has anyone experienced this problem and what was involved in fixing the problem? My budget has taken a hit from the last couple weeks of issues, so please offer suggestions.
Old Dec 16, 2007 | 08:06 AM
Default RE: Snapping Thud When Engaging Drive & Reverse
That has always been a small amount of a thud when shifting between gears, this is normal. In your case, based on your mileage, you have either a bad roto-flex on the rear drive shaft or two failing u-joints on the front drive shaft where it hooks to the t/case.
If you are not sure what to look for call me today and I'll walk you thru it.
303-862-7680
Colorado between 7 am and 8 pm
Old Dec 16, 2007 | 11:26 AM
philo73's Avatar
Thanks Disco Mike! The sound is definitely coming from the front drive shaft. Only in the last 2 days has it made such a sound....a pretty loud clank when engaging the gears. Does this mean she's ready to drop a shaft, or can I drive it to the shop?
[IMG]local://upfiles/8884/64A807F92B9D490EB28ED39D10CB555E.jpg[/IMG]
Old Dec 16, 2007 | 11:38 AM
Call me, there are a few things you should check before you decide on a repair.
Old Dec 17, 2007 | 02:00 PM
sideburns's Avatar
those front drive shafts are a ticking time bomb,lr should have a recall on them,when they let loose alot of times they take the trans case with them...get it checked asap
BMW
Nov 16, 2012 09:29 PM
RamblingMan
Feb 11, 2008 03:30 AM
vimal
Freelander
Dec 11, 2007 04:24 AM
Tanrover
Nov 26, 2006 04:09 PM
db1047
Apr 27, 2006 08:10 PM
