Disco II Radio Problems 02
I am at my wits end. The radio comes on and shows the stations and even what song is playing but no sound comes out. I checked all the fuses under the hood and inside on drivers side. I also checked the fuses under the front seats. All looks good. I even ordered a used amp and installed it and nothing. Any ideas??
My radio only comes on when I turn my headlights on. Radio goes off when I turn off my lights....sorry I could not help. I call it the disco gremlin...its one of many of gremlins in my disco. Also no low beams, only hi beams...
Good luck but sorry I could not help
It sounds like you may need either a new headlight/indicator switch (only having high beams is a common sign of failure) or you may have a problem with the rotary coupler (sometimes called the clockspring) which routes all the electrical from the steering wheel. The mode/volume switch combined with your headlight issues points to the possibility of either of these two or both being the culprit.
elboy0712
Oct 22, 2017 09:33 PM
4HVS
Audio/Visual Electronics
Jul 23, 2012 10:08 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
