Sponsored by: CARiD
Disco II Sunroof
Old Jul 6, 2007 | 03:12 PM
LMcInnis's Avatar
Default Disco II Sunroof
2000 Disco II... forward sunroof no longer responds to buttons... simply "chatters" when pushing the button. I can force it to run closed or open (i.e., push the window while holding the button), but am afraid of the potential damage.
Started as a tracking problem, push to tilt and it would slide back an inch also. Then an inch became 3, and 5, and so on, until it came completely unhinged (so to speak).
My mechanic refuses to work on it, claiming the roof liner has to come out - too much work and potentially thousands in labor.
Anyone know of a way to re-set the track or re-position the window correctly?
Appreciate any thoughts/insight,
Larry
Old Jul 6, 2007 | 06:52 PM
Default RE: Disco II Sunroof
You will need to replace the track and motor to get it back working. You should also be able to open the rectangular trim plate and open the sun roof with an allen wrench in the mean time.
Mike
Old Jul 6, 2007 | 08:07 PM
LMcInnis's Avatar
Mike, thanks. Where is this rectangular trim plate? I can find the track parts, the glass roof and a solid bar across the front edge of the glass, but don't see any trim plate (unless it's where the open/close buttons are?).
Appreciate your help (once again);
Thanks,
Larry
Old Jul 7, 2007 | 10:19 AM
Look up when sitting in your drivers seat, look at the vinyl trim up by the switch, it is in front of it.
Mike
Old Jul 7, 2007 | 10:42 AM
LMcInnis's Avatar
Ok, thanks. Got it closed for now,will leave it that way for the time being ($400.00 for new motor and tracks!!!).
Appreciate the assist,
Larry
Old Jul 8, 2007 | 09:37 AM
You need to verify if it is the whole assembly or just the motor. You can get good guaranteed motors cheap,
http://www.roverlandparts.com/index....S&Category=372
Mike
Old Aug 22, 2007 | 02:58 PM
sideburns's Avatar
replace both assy at one time
Old Aug 22, 2007 | 03:23 PM
ORIGINAL: sideburns
No real reason to replace both at the same time, the rear may last a lot longer, especially if it is kept clean and lubed.
bcolins
Aug 22, 2022 03:02 PM
BigRed98
Jun 21, 2010 12:30 AM
Princess
May 29, 2009 08:11 PM
LANDROVER LUKE
Mar 20, 2009 11:17 AM
blak3carr1ngt0n
Jul 21, 2008 04:46 PM
