Disco II transmission started leaking while in sport mode at 130kph
Hi All
I could use some help to figure out what has happened. I was on the hyw in my 03 Disco travelling at about 130kph in sport mode and saw smoke in the rear view. I slowed down to 60 took it out of sport mode and the smoke diminished. I was only a few minutes from home so drove home, no funny noises or issues with the tranny. I looked under the car and saw tranny fluid all over the cross member and down the drivers side frame members. It looked as if it spurted out of somewhere under pressure and splattered everything. Any ideas where this leak may have originated from? Any techniques to locate a tranny leak without having to drop it out straight away?
Any help would be much appreciated.
Cheers
Nelson
Cheers
Nelson
What I would do. First of all check all the fluid levels, or at least engine and transmission. Wash the mess. With the car clean, start the engine again and look for the leak. If it is not leaking and the oil levels are good, and like you said, no funny noises, then take for a short drive and check underneath again for the leak. By the way, I don't think the leak has anything to do with the sport mode. Do not discard that the oil could be from the transfer case. That needs to be checked next.
from the owners manual:
So at 80 miles per hour, I think the "S" may stand for a variety of descriptors besides "Sport"... like Soon 2 B @ stealership.
However, leak could be spray from a fitting headed toward the tranny cooler, red fluid sprayed well over a large area.
‘Sport’ mode
With ‘Sport’ mode selected, the gearbox is
more responsive to accelerator pedal
movement - downshifts occur earlier and
upshifts are delayed to make optimum use of
the engine's power while accelerating. Select
‘Sport’ when increased acceleration is required,
or when negotiating long inclines or twisting
roads. Note that driving in ‘Sport’ mode may
increase fuel consumption.With ‘Sport’ mode selected, the gearbox is
Thanks Buzz. Mine is DI and I don't have a switch for the S mode, I keep it there with my lead foot. On one of my other cars (listed below) the S is the normal mode and the other is Economy mode. Never go there.
But I don't want to steal this thread, let's hear about the leak!
the vehicle was last serviced 2 months ago. Fluid levels were all good. i had the tranny fluid changed 6 months ago less than 10,000 km on fluid since then. I know how to check the level. Will do so in the morning and let you know. Seems like a large amount of red fluid not leak from steering box etc. originates from just front of cross member somewhere. I was in sport mode on the Hyw to get some pasing power of a narrow two lane part didn't think of putting it back into regular mode once I hit the 4 lane freeway.
Looks like spray on some parts but liklely becuase of wind /speed. Any fittings in particuler or seals I should concentrate on?
Cheers
Nelson
Heres a layout of the cooling system. Notice the separate small radiator, with a plug hanging out, which is the tranny cooler, between the main radiator and the AC condenser. Oil cooler on the top, if so equipped. Tranny cooler on the bottom, has line each side, plus a sensor. These would be the most forward place a transmission fluid leak could begin. It is not unheard of to have a pin hole leak, a nicked line, or an O ring that went.
