Sponsored by: CARiD
Disco2 v8
Old Jul 29, 2018 | 12:15 AM
bodhinijen's Avatar
3rd Gear
Default Disco2 v8
gday
warm/hot air comes thru dash vents when a/c is off
can anyone help ?
Old Jul 29, 2018 | 02:27 PM
JUKE179r's Avatar
Set your temps to the lowest temperature setting before shutting off the temp control unit.
Or close your vents.
Old Jul 29, 2018 | 06:34 PM
bodhinijen's Avatar
3rd Gear
kool ! Thanks
also, I’m driving thru a lot of Desert country and am getting a lot of dust inside the car (windows closed)
(could be weakened door seals)
but someone recommended setting the air con a few degrees off the outside temp to pressurise the cabin ??
does this sound right ??
Old Aug 5, 2018 | 01:49 PM
Dave03S's Avatar
There is a vent in the back to prevent the cabin from pressurizing. Have you used the recirculate button on the HVAC control panel? If working properly that should block the fresh air intake. Your fresh air intake at cowl beneath the wind screen should have an intact and clean pollen filter to prevent dust.
Old Aug 5, 2018 | 09:27 PM
bodhinijen's Avatar
3rd Gear
Originally Posted by dave03s
there is a vent in the back to prevent the cabin from pressurizing. Have you used the recirculate button on the hvac control panel? If working properly that should block the fresh air intake. Your fresh air intake at cowl beneath the wind screen should have an intact and clean pollen filter to prevent dust.
thanks heaps
very informative
Old Aug 5, 2018 | 10:29 PM
Dave03S's Avatar
https://www.lucky8llc.com/collection...-pollen-filter
Drake Anderson
Feb 12, 2019 08:14 PM
escott16
Dec 28, 2018 05:36 PM
ReconDoc83
Dec 20, 2018 10:20 AM
ToiletDuck
Nov 18, 2018 03:45 PM
Satee John
Feb 28, 2018 05:19 AM
