Discovery 1 fuel pump cost .
If all you want/need is the pump motor itself, look for an Airtex 3270 or AC Delco EP241. Strainer is a Delco TS7.
This thread is useful.
https://landroverforums.com/forum/di...71/#post152377
Do you have an AEL truck or pre-AEL (Advanced Evaporative Loss)? The housings are different.
https://landroverforums.com/forum/di...02/#post567770
Use caution removing the hose connections from the top of the pump housing. They are likely to be brittle.
