Sponsored by: CARiD
Discovery 2 water leak
Old Oct 7, 2015 | 04:49 PM
bacino1960's Avatar
6th Gear
Default Discovery 2 water leak
Have a 2000 Discovery 2, outer edge of floorboards (carpet) front and back seats, is soaked with water.....running out in front of rear tires. All fluids are up, it's not antifreeze. It has not rained nor did I drive thru any water. Checked under dash, nothing wet. Any ideas.....Thank You
Old Oct 7, 2015 | 10:03 PM
Joemamma1954's Avatar
It sounds like your a/c drain pipes are clogged. There are several threads on the subject. There are two, one on each side of the transmission, and they have pointed nipples on them. They are condensation drains that drain from your A/C behind your dash out thru tubes going thru the hump over your tranny. Remove the nipples, clean and reinstall. Beware, it this is your problem, you will get soaked(at least your arms anyway)
Old Oct 8, 2015 | 07:45 AM
bacino1960's Avatar
6th Gear
Default water leak
Thank you so much.....that sounds very logical since the only water in the vehicle would have to be that and since it is both sides makes sense that it's coming from the middle and filtering to both sides. I also noticed yesterday that there was a large spot of condensation on the inside of my window in the middle that's all so new. thanks again for your help I will check it out
Old Oct 8, 2015 | 08:17 AM
bacino1960's Avatar
6th Gear
Default leak
Yes.....that was it, a.c. drain lines. And your right....I did get soaked, but worth it ! Thanks for your help ! B.
oilspotLR
Jun 7, 2012 10:49 AM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
rgrizzard
Mar 6, 2008 10:16 AM
