Sponsored by: CARiD
Discovery 3 Errors
Old Apr 9, 2020 | 11:31 AM
Altus Bylsma's Avatar
3rd Gear
Default Discovery 3 Errors
My Discovery 3 shows the following error messages
TRANSMISSION FAULT LIMITED GEARS AVAILABLE
PARK BREAK FAULT AUTO RELEASE NOT FUNCTIONAL
HDC FAULT SYSTEM NOT AVAILABLE
NOT ABLE TO START AT ALL
Where do I start with fault finding
Please assist
Old Apr 10, 2020 | 10:52 AM
enb54's Avatar
I'm sure others with more experience will chime in, but first I'd check that your battery connections and fuses associated with your problem are making good electrical contact and you have 12.7 or so volts at the battery before starting, then a common culprit seems to be the brake light switch (internal connections burnt/corroded), I automatically replaced mine when I bought the car even though I had no problems. Electrical problems like corroded connectors are also an issue, you would need to supply information in detail to get more specific responses, things like does it crank but not start, if it does not crank do you hear a clicking noise coming from the solenoid, what other error indications are there, what year and engine type is it (gasoline or diesel), do you have any codes from a code reader and so on.
Old Apr 13, 2020 | 03:55 AM
3rd Gear
Default Discovery 3
Hi Eric
Thanks for the reply.
If I turn the key / ignition this is the only messages I received, the engine didn't turn at all.
Tried 2 different batteries both above 12,7 volt
Its a Discovery 3 2008 S Diesel
Please find attached photos of the info screen
Attached Thumbnails Discovery 3 Errors-0ce1ddd5-3445-4db8-9ff1-8c61cf2ae61e.jpeg   Discovery 3 Errors-ba05e11b-f6f1-496b-8ac0-8b591733fa8b.jpeg   Discovery 3 Errors-baa0c0bc-7d23-4081-a8c5-ff18a253d889.jpeg   Discovery 3 Errors-8bc69918-918e-41b7-824d-bf8551144ae3.jpeg   Discovery 3 Errors-89208d08-5b4f-4f32-aad7-35d173104cad.jpeg
Old Apr 13, 2020 | 10:08 AM
enb54's Avatar
Altus...
A link on this forum to a very similar problem with a 2008 gasoline powered LR3 (North American D3) is at https://landroverforums.com/forum/lr...ny-more-97107/ . Just to give you a few more ideas, if you are uncomfortable with electrical issues get some experienced assistance...
Also read through this https://landroverforums.com/forum/lr...t-46701/page3/ thread, many problems with a defective brake switch...
Another thread with more comments is https://landroverforums.com/forum/lr...ult-hdc-68336/ .
Good Luck, some of these problems are very time consuming to diagnose...
Old Apr 13, 2020 | 10:55 AM
3rd Gear
Many thanks a hand full of ideas to explore
Where is the brake switch ? Is it the one behind the brake paddle you revert to
Old Apr 13, 2020 | 11:26 AM
enb54's Avatar
Brake switch is on driver's side and you have to remove the bottom dash cover and usually the face panel (makes job easier), there is a video on YouTube at
and another one at Atlantic British
bebushka
Feb 18, 2020 11:02 AM
e36m3
Feb 11, 2014 10:45 PM
chavhater
Nov 4, 2012 03:21 AM
dkim7803
Nov 7, 2007 05:44 PM
