Sponsored by: CARiD
Dll won't move
Old Jan 25, 2013 | 08:27 PM
  #21
The contacts are arranged as four outputs, which follow a chart on the attached pages. You can read with a meter.
W = Blue & Purple = pin 36 of tranny computer = pin 9 of XYZ connector
X = Blue & Black = pin 8 of tranny computer = pin 10 of XYZ connector
Y = Blue & Green = pin 37 of tranny computer = pin 7 of XYZ connector
Z = Blue and White = pin 9 of tranny computer = pin 6 of xyz connector
File Type: pdf
File Type: pdf
Old Jan 25, 2013 | 08:43 PM
  #22
Merritt87's Avatar
I'm a Lil lost. When I check outputs I should get 12v?
Old Jan 29, 2013 | 10:31 PM
  #23
Merritt87's Avatar
Well I'm going to send it to the shop ill get back and let y'all know what they find.
Old Jan 30, 2013 | 12:52 AM
  #24
re; When I check outputs I should get 12v
yes, per the chart from the RAVE. Measure between pin and frame ground.
Old Jan 30, 2013 | 01:38 PM
  #25
Merritt87's Avatar
I have sent it to the shop. I hate to do that but I have lots of work coming up and don't have the time to mess with her. Ill get back with you about what they find.
Old Feb 8, 2013 | 09:39 AM
  #26
Merritt87's Avatar
Well they told me I need a new trany.. I don't know how it would go out over night when it's not being moved.. Landrover has been a nightmare for me.
Old Feb 15, 2013 | 11:26 AM
  #27
saidrover's Avatar
Not sure about the tranny, but have you messed with the position of the xyz switch while changing gear lever positions. I recently had the MS and limp nightmare and at the end of it all the position of the xyz mounted to the tranny was my culprit. No more MS limp.
Smith CH
Mar 10, 2015 08:24 PM
jad568
Freelander
14
Apr 15, 2013 02:47 PM
mtrdrms
Jan 3, 2013 08:18 PM
Linda_Mn
Defender
Jul 28, 2009 10:43 AM
