Door Lock Actuator Unit
Ok, so I know what the problem is but have no idea how to fix it. My rear passenger side door will not lock and unlock with the rest of the doors. You can manually lock or unlock it and the actuator is working. Above the actuator inside the door is an "L" shaped lever with a connecting rod running from the tab we pull to the door lock. This rod crooks right above one side of the "L" while the other side is connected to the actuator. When this "L" turns it should move that rod to either lock or unlock the door, correct? How the heck do you get the rod connected with the "L" piece?? Thanks.
kristofferzen
09-10-2015 02:11 PM
bcolins
09-25-2012 08:40 AM
jfall
04-12-2012 03:26 PM
bcolins
11-08-2011 06:15 PM
