Sponsored by: CARiD
Door lock/mechanism query
Old May 21, 2009 | 11:46 AM
JeremyH's Avatar
5th Gear
Default Door lock/mechanism query
Hi I have a 96 Discovery and over the last year or so a couple of the door locks do not fully open. IE the lever that shoots up out the top of the door cards is lower than it should be by about 5 to 10 mm. As such you have to pull the leaver up fully from within the car to open the door/s, however when you shut the door it drops back down again. I have put this down to a worn component however is it something simple to adjust after removing the door cards for access? Or do I need to buy new parts?
Thanks
Jeremy
Old May 22, 2009 | 12:50 AM
defenderrich's Avatar
yes, you do. you need replace the door latch, the spring inside is weaker, can not hold the lever up.
Old May 22, 2009 | 10:02 AM
JeremyH's Avatar
5th Gear
Do you know if you can just replace the spring, as unless I use a new latch then I could end up doing the job twice.
Thanks
jeremy
Old May 22, 2009 | 11:21 AM
Not sure, if you can't, go to Roverlandparts.com and buy a good guaranteed used one.
Old May 24, 2009 | 07:37 PM
sector-9's Avatar
3rd Gear
Replacement springs for D1 door locks are available on ebay - it's a common fault.
Darren
Old May 27, 2009 | 02:12 AM
jiasds's Avatar
yes, you do. you need NY Escort replace the door NY Escorts latch, the spring inside is weaker, can not hold the lever up.
Do you NY Asian Escorts know if you can just replace the NY Asian Escort spring, as unless I use a new latch then I could end up doing the job twice.
sDot
Oct 1, 2013 08:53 AM
gamekakfan
Aug 17, 2009 06:18 PM
audiurq
Jul 1, 2007 11:52 PM
Str8BacardiL
Mar 18, 2006 10:57 AM
