Sponsored by: CARiD
Driver door open prompt on screen?
Old Jun 28, 2006 | 01:28 AM
97vitesse's Avatar
4th Gear
Default Driver door open prompt on screen?
I am having trouble with my driver door reading closed. Eventhough the door is physically closed the screen prompts that the driver door is open. So after opening the door and slamming it shut a few times it stills give me the same info driver door open. And my battery is also going dead if I leave it sitting for a day. I don't know if this is due to the door being open or what, because I have to manually turn off the interior lights when I exit the vehicle or else hey will stay on. Any suggestions?
Old Jun 28, 2006 | 09:59 AM
Landzu's Avatar
Default RE: Driver door open prompt on screen?
The door switch is most likely gone out.
Old Jun 28, 2006 | 10:03 AM
Landzu's Avatar
Its the little button that pushes in when you shut the door.
Old Jun 28, 2006 | 03:02 PM
I agree, check the door switch, also check the wire harness that goes from the door thru to the body of the truck, make sure it hasn't been pinched and you have a broken wire.
And whatever you do, QUIT slamming the damm door, all that is going to doo is break the window regulator and then you will have something to bitch about.
Mike
Old Jun 29, 2006 | 12:44 AM
97vitesse's Avatar
4th Gear
I may be a liitle slow but I can not find the door switch at all. Is it in a special location? I looked all over for it this morning and could not find it. Where exactly is it located on the RR. I will check the wire harness and make sure it is in tact. I will also quit slamming the damn door.
Old Jun 29, 2006 | 03:16 AM
Bait's Avatar
ORIGINAL: 97vitesse
Your not slow. You did not mention your year and Country. Your post suggests a NAS P38A Range Rover. No switch, it's all in the door latch assembly. First, check the connections @ the door jam by removing the rubber grommet. Most likely, bad latch.
Old Jun 29, 2006 | 10:11 AM
Landzu's Avatar
I thought it was a 97 Disco.
Old Jun 30, 2006 | 01:46 AM
97vitesse's Avatar
4th Gear
It is a P38 Range Rover. Is the latch assembly fairly easy to install? Where can I purchase just the latch assembly?
Old Jul 1, 2006 | 10:10 PM
Bait's Avatar
ORIGINAL: 97vitesse
No, the latch assembly is fairly difficult to replace. You must purchase it from a Dealer or authorized parts center, Atlantic British or Rovers North.
Did you check the door jam connectors?
joshp01
Dec 5, 2021 07:50 PM
leddifer
Jan 9, 2010 06:44 AM
DooDer
Dec 28, 2009 09:42 PM
GeorgeA
Jun 27, 2009 09:39 PM
