Sponsored by: CARiD
ECM or New Wheel Speed Sensor
Old Apr 28, 2010 | 07:31 AM
Spensive's Avatar
Default ECM or New Wheel Speed Sensor
Alright guys, I recently rented an Amigo from my club, read codes and had a shuttle valve electrical failure and front right low output on the wheel speed sensor. I have addressed the shuttle valve issue, code is gone, as for the front right wheel speed sensor, the hub assembly was replaced six months ago with a new hub assembly. The three amigos stay off until about 40-45 mph, then they are back, with the low output code. I have multi metered the wheel speed sensor turning the wheel by hand. Mike, tell me what to do next!
Old Apr 28, 2010 | 08:21 AM
hilltoppersx's Avatar
for the record the code is an ABS fault 044
after checking continuity on the sensor i'm not sure what else to reccomend.
i don't think you can swap the sensor for a sensor on the other side so the only option might be to try and get your hands on a junked truck and pull the sensor from there to see if it actually the sensor and not something else causing the fault. I say a junked one just because it will cost you all of $15 from a junk yard but I believe the sensor new is a little over $100.
lets wait to hear what Mike or Spike have to say. What happened to Josh? he
was so busy with fixing every ABS issue on the island maybe he came across the 044.
Old Apr 28, 2010 | 08:28 AM
Spensive's Avatar
Gotcha, next step is to look at all the connections.
Old Apr 28, 2010 | 08:44 AM
Things that will also cause a speed sensor fault can be a warped rotor, squeaking brakes and bad bearings in the hub.
When you replaced the hub, was it a new one from Rover with a new speed sensor included, if so you have a 1 year warranty.
Old Apr 29, 2010 | 10:00 AM
Spensive's Avatar
Thanks for all the help, just wanted to update this, ordered new rotors and brake pads this am, will have Monday. Let you guys know the outcome.
todd0765
Dec 7, 2012 07:23 PM
twaszak
Jun 4, 2011 07:49 AM
soccerinco
Oct 18, 2009 12:44 AM
acegt1
Jun 3, 2008 12:56 PM
Switzer
May 31, 2008 09:58 AM
