Cleaning Wheel Speed Sensor(s)
Old May 30, 2008 | 10:20 PM
Switzer's Avatar
Default Cleaning Wheel Speed Sensor(s)
As the title suggests, I would like to test the waters and see if anyone can offer some information on cleaning/checking the wheel speed sensors. My Rover offers me the three amigos (ABS/ETC/HDC) lights quite randomly and in varying conditions. Brake squeal has not presented itself when the lights came on. I believe a quick check and cleaning (if that is possible) may reduce the appearance of the amigos. Thanks for any replies!
Cheers,
Pete
Old May 30, 2008 | 10:29 PM
Default RE: Cleaning Wheel Speed Sensor(s)
That usually does the trick, but I have never messed with mine (DI), but I think that you can just spray brake cleaner on them and then check to see if they are seated properly. Check your connections too.
Old May 31, 2008 | 09:01 AM
Don't mess with something that will possibly cause you to buy additinal parts.
If you brake hard, do you feel the ABS pulsate thru the brake pedal, if so, your your control unit is fine. Do your brakes squeak? This is the most common cause for the lights coming on.
Old May 31, 2008 | 09:58 AM
Switzer's Avatar
The ABS functions correctly under heavy braking. The warning lights do not return after restarting the engine. The brakes squeal from time to time, although it is on an irregular interval and very faint. New brakes are on my maintenance list. Based on the given advice I will leave the sensors alone.
Cheers,
Pete
twaszak
Jun 4, 2011 07:49 AM
vandal996
Feb 17, 2011 09:44 AM
Spensive
Apr 29, 2010 10:00 AM
soccerinco
Oct 18, 2009 12:44 AM
acegt1
Jun 3, 2008 12:56 PM
