EKA problem (Enigine disable press remote or use key code)
Please help.
I got a Land rover Range rover 1996 2,5tds. In past the Eka problem has come up some few times. When this happened i used to go outside of the car and do the "lock and unlock procedure" and this always worked.
Land Rover EKA Code (Emergency Key Access) Code
Today this problem came up once again.. but it didn't work with usual key procedure. at the end of this procedure the alarm used to make a beep noise twise but this didn't happen today. I i tried a few times, waited the time to try more but nothing happened. I even tried with key nr. 1 and nr. 2... I read that i could try a "restart". The restart was unplugging the battery and wait for 5 minutes and then plugg it back in, but nothing changed
Is there something i missed or sould to diffrent ?
Please help.
aarongregor
01-21-2013 11:39 PM
khuds308
04-12-2012 12:55 PM
