Sponsored by: CARiD
Electrical Help 02 Disco
Old Dec 29, 2008 | 07:10 PM
haRley C.'s Avatar
3rd Gear
Default Electrical Help 02 Disco
I was changing my drivers side headlight plug, because it kinda melted a bit? When I was checking to see if it had juice going to it and accidentally touched the ground with the live wire. They arced and then of course nothing... So needless to say it blew a couple fuses, but when I replaced the fuses that blew there still was no juice going to it? I tried everything I could think of until I could not feel my fingers from the cold anymore then gave up. I did notice a plug and harness on the drives side that has a light blue wire that loops from it, back into it. In my repair manual it does not have mention of this plug? Or if it does I could not find it... Could it be some sort of fuse and I blew it? I'm pretty much stumped!
Thanks,
Harley C.
Old Dec 30, 2008 | 06:32 AM
rinmud's Avatar
Default RE: Electrical Help 02 Disco
You probably replaced the wrong fuse hold it up to the light and make sure the element is indeed failed, try the brights. It may have smoked the switch but usually its the fuse. scott
aprost
May 31, 2006 07:50 PM
subswoopes
Audio/Visual Electronics
May 31, 2006 04:16 PM
Knep
Feb 23, 2006 12:01 AM
JRdisco1
Jan 4, 2006 11:31 PM
My98disco
Aug 4, 2005 01:21 AM
