Sponsored by: CARiD
electrics
Old Apr 18, 2016 | 05:44 AM
Hawkins3231's Avatar
7th Gear
Default electrics
In my 96 doscovery when i change gear my cd olayers turns off and on again also when i take my hand brake off its dims my lights could this be a loose wire behind where the window buttons ares in the central part ?
Old Apr 18, 2016 | 09:49 PM
XCELLER8's Avatar
its likely that you have a ground issue.....start by checking the battery cables...and all the ground cable points....there is a common ground point behind the drivers side kick panel that usually rusts,......you may need to look at the wiring around the shifter and e brake to make sure something isnt shorting there. It's not that bad a job to pull the center console and have a look....sometimes loose change and all kinds of debris can fall down in there and cause some trouble
Byte
May 20, 2008 08:23 PM
rwarren92
Engine & Internal
Apr 28, 2008 09:15 PM
gsgtsg
Feb 28, 2008 06:36 PM
alanroberts50
Nov 21, 2007 08:48 PM
edbar
Jan 1, 2005 09:08 AM
