Sponsored by: CARiD
Engine faltering on the freeway
Old Jan 17, 2011 | 07:46 PM
wlundquist's Avatar
Unhappy Engine faltering on the freeway
My 98 Disco I (109K miles) has started losing significant power at freeway speeds. It happens primarily at RPM < 3000 under acceleration and the engine will just start to run rough with no power. If I push hard on the gas usually it will downshift and the engine fully powers up, or if I back off and back on the pedal power returns. My mechanic checked the fuel pressure and it was good, and I just installed new plug wires and recent new plugs. Check engine had misfire noted in two cylinders and my mechanic reset it, and it did not come back on until 50 miles later even though the frequent power cutout problem kept recurring. I drove it to Tahoe this weekend (400 miles) and the problem just kept coming up, but did not seem to worsen much. Any ideas here?
Old Jan 22, 2011 | 12:24 AM
afirover's Avatar
Speed sensor will do this every time
Old Jan 25, 2011 | 03:02 PM
jackpar's Avatar
3rd Gear
Default I suspect sticky exhaust valve?
My 96 disco does the same thing, and I have concluded that it may be a sticky exhaust valve- typical Seafoam cleanout may not work, and I may be facing removing the heads and doing a valve job. I will keep following this thread to see others' input.
Lord Wert
Jun 5, 2013 11:38 AM
s10lowrider1994
Jan 7, 2013 09:41 PM
gunsanroses91
Sep 9, 2012 11:17 PM
bevi1970
Oct 31, 2011 03:27 PM
wlundquist
Jan 26, 2011 02:17 PM
