Sponsored by: CARiD
Engine Identification & Door
Old May 2, 2011 | 10:31 AM
gman1001's Avatar
5th Gear
Default Engine Identification & Door
Hi there,
So my neighbor has decided to GIVE me his 2001 Discovery. A shade tree mechanic diagnosed bad head gaskets, the symptom, no power etc... also confirmed no hydro lock.
My mechanic, not shade tree wants me to find out what engine is in the car prior to me committing to something big here.
Any hints out there on how to figure this out? VIN maybe?
Also - the read door. Its not stuck shut like so many have posted here. But it opens stiffly. I couldn't help but notice the metal bar at the bottom of the door. Totally rusted. There must be a sticky on this site about this mechanism no?
Tx in advance!
Garrett
Old May 2, 2011 | 07:54 PM
There are 2 different "engines" for the DII, they are actually the exact same engine just different emissions systems.
Here is how you find out...Landrover Discovery - Product Instructions for Landrover Parts
They both use the same headgaskets, the only difference will be the spark plug temp range.
As for the cargo door, the door stay needs to be lubed every 6 months at least, use silicon spray to free it up and then use bike chain lube.
Open it all the way, spray all along the door stay channel, then close the door, open, close, lube...until it starts to move freely.
Also using the silicon spray pop the Land Rover emblem off of the door handle and spray and work the handle on the cargo door.
Spray the latch too, do this to all moving parts, all door hinges, latches, hood cable and latch, door locks...if it moves it needs to be lubed.
Silicon spray will not attract dirt, this needs to be done every 6 month, more often if you live on a dirt road or where there is lots of road salt and grime.
Punter
Defender
Jul 6, 2022 04:57 AM
0304Disco
Jan 25, 2012 09:39 PM
0304Disco
Oct 13, 2011 08:00 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
