Sponsored by: CARiD
Engine races when idling
Old Jul 25, 2007 | 07:59 AM
richardgatekeeper's Avatar
Default Engine races when idling
Hi. I have a very unusual problem with a Landrover 110 (2.5 turbo diesel), and hope that someone may know what is going on. After the engine has been idling for 10-15 minutes, on touching the accelerator just slightly, the engine races to well above full throttle RPM -ie.screaming revolutions - forabout 5-10 seconds before dying back to idle speed.Advice frommechanics suggested oil-carry-over from the engine breather into the air intake before the filter, causing the engine to run-on from directly ingested oil. But disconnecting the breather pipe has failed to stop this happening, and every 6 months or so it happens aqgain. This is very disconcerting, and you feel as though the engine is about to disintegrate! The engine has done 135,000 miles without rebuild, but uses very little oil even after a 500 mile trip. It does not appear particularly worn, there is very little blowing-out of oil from the breather pipe to speak off, but power has dropped off about 10-20%, possibly we think from a worn turbocharger. Does anyone have ANY ideas at all what could be causing this? MANY THANKS.
Old Jul 25, 2007 | 05:58 PM
Default RE: Engine races when idling
Could this be a result of oilfrom an oil leak tothe turbo-charger bearings being sucked into the engine and burnt as soon as you touch the accelerator, as air flow into the engine increases?
tibyABv6
Nov 10, 2010 07:23 PM
eriqcharlz
Jul 3, 2007 09:30 AM
EVN137
May 30, 2007 07:24 PM
2tall4u
Jul 26, 2006 05:50 PM
LANDY1998
Freelander
Sep 18, 2005 09:35 PM
