Sponsored by: CARiD
Is engine really dead?
Old May 14, 2016 | 10:21 AM
klandrover's Avatar
Default Is engine really dead?
Took truck to shop to try to pass emissions. Cost &600. List of things they did. Can cylinder not be fixed? Say I need new engine. Is engine really dead?-p_00648.jpg
Camera not good hope you all can read.
Old May 14, 2016 | 04:11 PM
MrValingo's Avatar
Without compression on cyl 5 you either need to rebuild or replace. Replacing with a used engine would be the easiest route
Old May 14, 2016 | 05:02 PM
number9's Avatar
Believe a stuck/seized open valve could cause zero compression as well. You don't hear of many zeros.
Old May 14, 2016 | 08:50 PM
Charlie_V's Avatar
Almost surely a valve.
Get a new head (or better yet, take yours off and to an engine shop to have valves done) slap it on, flip off the inspection station, bask in glory.
Even broken piston rings will give you some compression unless all three layers are broken.
Unless there is a hole in the cylinder that you can see it would (almost) have to be valves, as Number9 said.
Old May 14, 2016 | 09:27 PM
XCELLER8's Avatar
as above...get the heads off of it....things will be a lot more evident at that point
Old May 16, 2016 | 10:40 AM
klandrover's Avatar
Thanks all. I am taking it to a new place tomorrow after letting him read printout. He says like you do. So next question: what could happen if I drove without cylinder 5?
I think I have been for a couple of months already. Will engine sieze?
Old May 16, 2016 | 10:45 AM
Charlie_V's Avatar
Unburnt gas from the number 5 misfire will thin your oil and could ruin your catalytic converter. It will also put stress on the crank.
If you pull the oil dipstick it probably smells like gas.
Old May 16, 2016 | 02:03 PM
klandrover's Avatar
Default Does this look right?
I went to check if the drip stick smelled of gas. Maybe a bit couldn't tell not strong. I also noticed what looks like a bicyle plug on the engine. See photos where it looks like hoses should be but aren't. Opinions?
Attached Thumbnails Is engine really dead?-p_00654.jpg   Is engine really dead?-p_00651.jpg   Is engine really dead?-p_00650.jpg
Old May 16, 2016 | 03:28 PM
fishEH's Avatar
Pic 1: Fuel rail pressure valve.
Pic 2: Hood switch plunger, its ok.
Pic 3: Spark plug wire retainer clip, its ok.
Old May 16, 2016 | 03:43 PM
OverRover's Avatar
In pic 1 you might want to replace the hose/ valve cover to ram housing. Just get the kit > PCV Tune-Up Kit For GEMS Engines | Land Rover Engine Parts
Simple install >
