Sponsored by: CARiD
engine rebuild with secondary air
Old Oct 30, 2015 | 06:03 PM
robersonb's Avatar
Default engine rebuild with secondary air
Does anybody know if the hard pipe that goes across back of the engine must go on before manifold and whether it goes above or below the coil packs? Can't find any pictures in the RAVE that go along with the secondary air or anything online.
Old Nov 9, 2015 | 02:15 PM
dougwrench55's Avatar
Default SAI crosspipe
you install the coils and the cross pipe after installing the lower manifold otherwise you have no access to the fuel line connection. Pipe goes over top of coils and the top 2 retainer bolts run through both the coil bracket and the pipe bracket. I hope that helps.
isofast
Mar 15, 2017 03:02 PM
d.m.disco
Apr 11, 2010 09:32 PM
jallert
Mar 3, 2010 07:28 PM
kjgale
Jul 23, 2009 03:07 PM
