Sponsored by: CARiD
Erase codes from A/C Control panel
Old Jan 27, 2011 | 12:23 AM
felipe55's Avatar
5th Gear
Default Erase codes from A/C Control panel
Hi I am from costa rica , and i have a issue with my discovery 2001 V8. The A/C control panel have some codes and I will like to know how I can erase those codes.
Regards
Old Jan 28, 2011 | 09:26 AM
jhonmathew's Avatar
5th Gear
If you have a control unit, which the EC is probably preserved in the button code or the version of the DTC error code for the coolant sensor. While the compressor is removed and the tax code is treated correctly.
Old Jan 28, 2011 | 12:20 PM
felipe55's Avatar
5th Gear
Hi actually the service light is on and the error code is for the coolant sensor,so you tell me that the problem could be the sensor coolant ?
Regards
Old Jan 28, 2011 | 06:26 PM
lordmorpheus's Avatar
That last post was just spam (you can tell by the link in the signature).
What codes are you getting? Until you fix the problems, the codes are going to come back. I believe the only way to clear them is with a scan tool, but hopeully someone else will chime in.
Externet
Aug 1, 2012 07:35 PM
felipe55
Jan 27, 2011 08:32 AM
elboy0712
Feb 19, 2010 06:53 PM
jason.xiao
Aug 1, 2009 06:57 AM
ehmontiel
Sep 2, 2008 11:05 PM
