Sponsored by: CARiD
Fault Codes diagnosis help needed
Old Mar 26, 2023 | 10:19 PM
PaulT999's Avatar
Post Fault Codes diagnosis help needed
Hi,
My discovery 3 is coming up with a suspension light fault sometimes. Sometimes everything seems to work fine and sometimes it won't allow me to raise or lower the suspension and or access the various terrain modes.
I ran a diagnostic and got the following error codes
C1A20-64 Permanent: Pressure increases too slow when filling reservoir
U0122-87 Intermittent: Lost communication with vehicle dynamics control module.
C1A00-88 Permanent: Control Module
U0132-87 Permanent: Lost communication with ride level control module
U0155-87 Intermittent: Lost communication with instrument cluster control module.
I wondering what this could all mean, and the best approach to find out what the issue is?
Thanks
Paul
Old Mar 27, 2023 | 08:09 AM
mollusc's Avatar
You should post in the D3 forum. Get more eyes on your message there.
Old Sep 12, 2023 | 07:30 PM
southpaw3229's Avatar
3rd Gear
Hey Paul, did you ever figure it out. I pretty much have the same fault codes. My LR3 backend suspension started to slowly drop while I was driving and the tires where rubbing against the frame. I ended up pulling the raise suspension switch and that temporarly fixed it but trying to figure out the issue and have a scanner.
Thanks
Old Sep 12, 2023 | 07:36 PM
PaulT999's Avatar
Originally Posted by southpaw3229
Hey Paul, did you ever figure it out. I pretty much have the same fault codes. My LR3 backend suspension started to slowly drop while I was driving and the tires where rubbing against the frame. I ended up pulling the raise suspension switch and that temporarily fixed it but trying to figure out the issue and have a scanner.
Thanks
I ended up replacing the compressor, cleaning the compressor intake filter, replacing the reservoir valve block, and repairing a leak in the reservoir tank end bolt. Ie I had multiple leaking issues. It sounds like you might have a faulty rear valve block.
Old Sep 13, 2023 | 02:21 PM
3rd Gear
Thanks Paul for replying. I will check into the rear valve block.
Thanks again,
Bay
Old Nov 25, 2023 | 12:13 PM
danyjames_9's Avatar
Banned
steevo67
May 23, 2025 12:59 PM
Dixie
Nov 5, 2023 09:39 AM
Atticus_6147
Jun 5, 2019 03:24 PM
bluetick
Jan 6, 2019 08:31 PM
