Sponsored by: CARiD
Finally got the Land Rover fixed, and now the alarm won't stop going off
Old Feb 26, 2011 | 11:14 PM
Bazzy's Avatar
6th Gear
Default Finally got the Land Rover fixed, and now the alarm won't stop going off
We just disconnected the battery because as soon as it's back connected the horns honking lights flashing...it becomes ..well...a disco.
Just had the starter put in took it around the block, shut it off and went to turn it back on, and all was dark , so figured one of the terminals were loose on the battery. As soon as it was reconnected all lights went on and withing minutes the alarm went off. The only way to shut it off was by unhooking the battery. I've looked through the forums and have seen something about an alarms swith under the hood....where would that be? Any help would be greatly appreciated since it's been since September that I've not had this car, and I was really looking forward to having it back. ...and if it needs to be reset, how does one do that? I'm at a loss, and would be so grateful for your help It's a 1997 Discovery...and I'm a sad chick from Massachusetts
Rachel
Old Feb 27, 2011 | 11:56 PM
roving patrol's Avatar
Did you try locking and unlocking the driver side door while the alarm is going?
Old Feb 28, 2011 | 02:23 PM
Bazzy's Avatar
6th Gear
Thanks Roving, yes I saw that in another post on here so I gave it a go and was thrilled that it worked! woo hoo! so thrilled to have it back running...although one of the battery teminals is cracked so...gotta do that first...if it's not one thing....
Thanks for your response, I appreciate it
Old Feb 28, 2011 | 02:46 PM
zim.dave's Avatar
4th Gear
Good to know, My Discovery has started locking itself, bit of a problem if you jump out to open the gate, locked out and engine running.!!! Any idea's what I can try to get over this..
Marnold-98-Disco
Mar 15, 2023 03:32 PM
ayzerlazer
Jun 9, 2015 03:36 PM
TATZOO
Jun 10, 2013 05:22 PM
Analogkid
Oct 28, 2010 05:38 PM
nelbra
Sep 23, 2009 10:55 AM
