Sponsored by: CARiD
Front drive shaft broke.
Old Dec 8, 2014 | 08:16 PM
samsax100's Avatar
4th Gear
Default Front drive shaft broke.
Hi folks, new to the group. I own a 2003 Discovery. Recently the front drive shaft broke loose form the transfer case. Now it will not go into gear, any gear. Is it possible the tranny linkage was damaged or has it sometime to do with being AWD. Thanks Sam
Old Dec 8, 2014 | 09:27 PM
lordmorpheus's Avatar
Welcome to the forum. The front drive shaft breaking is a somewhat common problem on these vehicles due to the factory u-joints not being grease-able. Often when the drive shaft breaks (if at speed) it will smash into the transmission knocking a gaping hole in the case. If the transmission is not able to shift into a gear, this is possibly what has happened. Time to crawl underneath it and look for damage.
Old Dec 8, 2014 | 09:47 PM
samsax100's Avatar
4th Gear
I haven't noticed and fluid leakin from the the tranny, just some from the seal where the u joint attaches. Think it could have damaged the linkage
Old Dec 8, 2014 | 10:08 PM
Kenso's Avatar
What exactly do you mean when you say it won't go into gear? Like the shifter won't move or just that it doesn't go anywhere when you shift it into gear? With the driveshaft broken and an open center diff in the transfer case, it's normal for the truck not to move if one of the driveshafts is disconnected/broken.
The shift cable is on the opposite side of the trans from the driveshaft, the driveshaft would be more likely to destroy the rest of the transmission before it would affect the shift cable.
Old Dec 9, 2014 | 07:50 AM
dusty1's Avatar
^ that. If it is in gear and not going it is the lack of driveshaft
If shifter will not budge check to see if brake switch is working. (Can you hear it, lights working)
Old Jan 12, 2015 | 06:26 PM
samsax100's Avatar
4th Gear
Thanks Lord Morpheus. After closer inspection that's what it is About a 3" hole in the tranny case. Guess I'll be replacing it and drive shaft when I have the money or may sell it as. Anybody want the piece of junk? Make me an offer
Old Jan 12, 2015 | 07:05 PM
A location would help if you are looking for offers. That said a used transmission isn't really that much money for these. Especially if you are doing your own work.
Old Jan 12, 2015 | 07:30 PM
Shiftonthefly1's Avatar
Drive shafts don't just fall out because of bad design. It's usually the incompetent owner/operator failing to rub a few brain cells together and check out the vibration. Before it grenades.
But clearly it's the piece of junk truck's fault.
Old Jan 12, 2015 | 10:31 PM
samsax100's Avatar
4th Gear
I'm 57 yo and have been driving since I was 13. Never in all the years had a drive shaft come apart. I had only owned the rover for a couple months and thought maybe the roaring was inherent to the Rover. From what I've read here it is a bad design, no zerk fittings. Incompetent hardly. I'm an industrial maintenance tech and repair things much more complicated than a vehicle. I came here for advice not smartass remarks.
Old Jan 13, 2015 | 12:01 AM
dusty1's Avatar
noted.......but I have been involved with about 2 dozen drive shafts (twist, split, strip, crack, separate, etc ) break......even pole vaulted a couple of times, and only 1 was on a rover. I think he was suggesting that the lack of lube/maintenance (p/o) from neglect was the cause, not the truck.
