Sponsored by: CARiD
Fuel?
Old Nov 7, 2007 | 12:32 AM
vjm530's Avatar
Default Fuel?
Bought a clean '97 4.0 Land Rover with 148k miles and love it. My questionis, the manual says, "Only use Premium Octane gas'." Can anyone tell me if it's possible to use a lower octane or recommendation? With gas prices in California what they are it would sure help. If not . . . oh well. Thanks for any input.[8D]
Old Nov 7, 2007 | 07:41 AM
Default RE: Fuel?
With regular 87 octane, you will carbon up the engine, loose power and about 2 MPG.
Main reason is that if you carbon up your heads, you can damage your valves and boy it isn't worth it.
Old Nov 7, 2007 | 08:30 AM
Landzu's Avatar
Default RE: Fuel?
Its a pay now or,,,,,,,pay later.
Pay now its much better.
Old Nov 7, 2007 | 09:23 AM
vjm530's Avatar
Default RE: Fuel?
Thanks for the honest answers. This is a great forum and I'm sure I will get a lot of mileage from it. Thanks again.
Old Nov 7, 2007 | 10:07 AM
Default RE: Fuel?
If you want to improve your mileage consider, new 02 sensors, new Magnacor plug wires and a good set of Bosch Platium Plus 4 plugs.
Old Nov 8, 2007 | 02:13 PM
bavarian_range89's Avatar
Default RE: Fuel?
I started out using premium 93 octane, but I have been using mid-grade ever since gas exceeded $3.00/gallon in South Carolina for my '02 Range Rover. I know the minimum recommended rating is 91, but I just assumed 89 would be okay. Is the 89 doing me damage?
Old Nov 14, 2007 | 04:04 AM
rumpig70's Avatar
Default RE: Fuel?
i have an 93 RR v8 which i run on nothing less than 95 octane and it killed me to keep the fuel up to it. I went out and brought a pod fillter,it cost me close to $60 aus for all connections and fitting is easy but it has cut my fuel bill by more than a third and in 2 weeks i`ve saved more than the cost of the parts and the time spent was more than worth it..
Old Nov 14, 2007 | 07:57 AM
Default RE: Fuel?
ORIGINAL: bavarian_range89
You know what they say about assuming???
You will cost your self more in repairs and maintance using anything less then 91 octane, as well as loose at least 1 MPG.
Old Nov 14, 2007 | 07:58 AM
Default RE: Fuel?
What is this Pod Filter you mentioned?
Old Nov 15, 2007 | 03:33 AM
rumpig70's Avatar
Default RE: Fuel?
its like a high performance air fillter they use alot on turbo motors,its a cone shape and the total surface area is fillter it gives greater air flow to the engine eg: better performance and less fuel.in oz they range from $30 to $130 the later being a washable one which they say can last up to 200,000 klm you can also get adapters to create your own cold air intake.
