Sponsored by: CARiD
Fuel?
Old Nov 15, 2007 | 08:23 AM
Default RE: Fuel?
Just like the K&N filters, any washable and oiled filter will cause your MAF to fail. I would seriously suggest you not use these, MAF's are not cheap.
Old Nov 18, 2007 | 04:04 AM
rumpig70's Avatar
Default RE: Fuel?
please excuse my ignorance here mike cause i do value your opinion but what is an MAF? i`m new to theLR game and am trying to gain as much knowledge as i can,it is a k&n fillter and i`ve used these on all my recent cars from 4clnd to 8clnd for many yearsand so far i havn`t had any adverse effects.ford, gm or other they all seem to preform better with this type of fillter.
Old Nov 18, 2007 | 07:19 AM
Default RE: Fuel?
On 99 and newer Disco's and Range Rovers, they use a Bosch MAF, mass air flow sensor, which is to sensitive to oil contamination caused by the oil on the K&N filter. So the MAF dies, truck runs like crap and you get to put out $130 for a new MAF.
Old Nov 18, 2007 | 04:57 PM
bavarian_range89's Avatar
Default RE: Fuel?
ORIGINAL: Disco Mike
ORIGINAL: bavarian_range89
I started out using premium 93 octane, but I have been using mid-grade ever since gas exceeded $3.00/gallon in South Carolina for my '02 Range Rover. I know the minimum recommended rating is 91, but I just assumed 89 would be okay. Is the 89 doing me damage?
You know what they say about assuming???
You will cost your self more in repairs and maintance using anything less then 91 octane, as well as loose at least 1 MPG.
Thanks discomike, you are probably the most helpful person on here. I will be using 93 octane from now on... but I will say my MPG never changed from 14 when I switched from 93 to 89, nonetheless I will be feeding Nigel premium from now on. [My girlfriend named the dude on the navi Nigel because of the brit-accent and it just kinda stuck, I know it should be a female name, but Nigel seems to be more fitting]
Old Nov 18, 2007 | 05:01 PM
ajh's Avatar
ajh
Default RE: Fuel?
The time you'll see a mileage loss is when the 89 is mixed with Ethanol which per-litre has about 25% less energy than petrol. If their midgrade is entirely petrol and you're not getting any knocking (or timing retardation to prevent it) then mileage should be about the same.
Old Nov 19, 2007 | 04:20 AM
rumpig70's Avatar
Default RE: Fuel?
so on a 93 it should`nt be a problem?...
Old Nov 19, 2007 | 07:40 AM
Default RE: Fuel?
91 octane and up is great.
Old Nov 19, 2007 | 09:30 AM
ajh's Avatar
ajh
Default RE: Fuel?
1993? That could be the low compression engine actually, in which case regular is fine.
Old Nov 20, 2007 | 02:08 AM
rumpig70's Avatar
Default RE: Fuel?
thanx guys.your help is truley valued..
JumPeR04
Apr 7, 2011 09:52 PM
40ranger
Apr 7, 2008 12:20 AM
jbond0076
Mar 16, 2007 10:11 PM
