Sponsored by: CARiD
fuel pump repair/replacement
Old Mar 31, 2017 | 08:35 PM
Lisa Potts's Avatar
5th Gear
Default fuel pump repair/replacement
I have just been given a 1998 range rover. Last wish of dying aunt to give it to me to give to my son next year for first vehicle. Unfortunately, it won't start. It did, albeit, not an easy start, but suddenly won't start at all. I had a mechanic friend put it on computer for errors, of which he found none. He did, however, get a fuel pressure reading of 14. He suspects a fuel pump and a fuel filter will solve this problem. Much to my dismay, the $60 fuel pump we initially found online does not fit our vin#WA392883. It only goes up to #WA37's. Our pump seems to be around $500!!! It is at his garage now, not yet dropped the tank to remove the pump. Does anybody have any suggestions on a more cost effective replacement? Can the pump be rebuilt and use the original assembly? Many thanks for help...
Old Mar 31, 2017 | 08:38 PM
Lisa Potts's Avatar
5th Gear
P.S. I was given an original part #wfx101390
Old Mar 31, 2017 | 09:08 PM
notny41's Avatar
You probably don't need to drop the tank. Lift up the carpet in the back and there should be an access panel that you can take the 6 screws out and have access to the pump.
https://landroverforums.com/forum/di...tarting-80279/
mine was $60 shipped off of ebay
Old Mar 31, 2017 | 09:10 PM
Lisa Potts's Avatar
5th Gear
No access from inside. Already looked. This was a bad year..lol.
Old Mar 31, 2017 | 09:30 PM
notny41's Avatar
Oh shoot - sorry, didn't see that it was a range rover rather than a discovery.
Old Apr 1, 2017 | 02:59 AM
The Deputy's Avatar
An aunt would really, really have to hate her grandson...to give him a Discovery...lol.
Old Apr 1, 2017 | 09:41 AM
abran's Avatar
Look at this on eBay:
https://www.ebay.com/itm/152483361496
1998 Range Rover P38A Fuel Pump Rebuild Kit for STC4345 Fuel Pump WFX101030 NEW
Old Apr 1, 2017 | 12:50 PM
Lisa Potts's Avatar
5th Gear
Thanks..I was looking at that one too. Seems, what I can gather, that the stc4344 is for 95-97. The stc4345 is supposedly 1998 & later. Although the original # isn't exact that the seller quotes replacement for. I will send them a question or two. I think my mechanic should have the tank down and old one out this week. Something tells me to be patient & get a look at the original before pulling the trigger.
Old Apr 9, 2017 | 03:04 PM
Lisa Potts's Avatar
5th Gear
Just a quick update. Mechanic got tank down, pump out. Using some specs he got somewhere???, he tried unsuccessfully to match up with similar year caprice...would have worked but not enough pressure. Ended up with a 1996 berretta pump...more pressure. Everything working like it's new. Don't know how long it will last, but for $50 bucks and some beer, not a bad fix for the moment.....oh, $65 if you throw in the fuel filter...
Travelor
Sep 24, 2015 06:11 PM
fishEH
Apr 28, 2012 09:32 AM
JumPeR04
Apr 7, 2011 09:52 PM
britbranch
Jun 19, 2009 05:59 PM
