Sponsored by: CARiD
gems to bosch replacement
Old Nov 10, 2009 | 10:13 AM
garcia1000's Avatar
Default gems to bosch replacement
Hey guys i know that there was a thread on a swap from a 4.0 gems to a bosch 4.6, i just cant find it right now.
however my dilema is i have an 03 disco 4.6 bosch with hole in the block. i found a 96 4.6 gems and purchased it. i know it will fit but, i am not sure if it needs som type of modification to run the bosch sytem. i only plan on using the block from this 96 engine.
Any help, please.
Old Nov 20, 2009 | 10:46 AM
You can only use the engine block, not the heads, manifolds or sensors. You might want to send me your number so we can talk, cause this may not be worth your doing.
Old Nov 22, 2009 | 07:07 PM
common's Avatar
Oh yeah, sweet. I hope to chat with several people in this site. A friend of mine suggested that I peruse these fiction forums to contact interesting people
Old Nov 24, 2009 | 10:30 AM
garcia1000's Avatar
Hey Mike, thanks for the advice.
I am only using the block and i found that the only sensor that may have to be modified is the crank position sensor. i have all the other parts ready form my 03 disco. i will documenting, and taking pictures of this swap and i will post them when i am done. hope fully i can start after thanksgiving.
thanks again mike, and have a good thanksging.
David Kadasia
Jul 15, 2017 10:22 AM
RoverBuild
May 30, 2012 09:56 PM
BW_Hunter
May 24, 2012 01:56 PM
toad2
Aug 19, 2010 09:13 AM
MOTERO5
Mar 26, 2009 10:30 PM
