Sponsored by: CARiD
Head Gasket Question on RR
Old Nov 27, 2009 | 09:40 AM
Young's Avatar
Default Head Gasket Question on RR
I've heard several people mention smoke coming from the exhaust when a head gasket is faulty. Does it continue to smoke or only at startup?
Old Nov 27, 2009 | 10:04 AM
Baylink's Avatar
If you have a failed/failing head gasket, you're going to be sucking one of two things into the combustion chamber that don't belong there: oil, or coolant.
Oil will give you smoke; coolant will give you steam.
Generally, yes, once you have a failure, it will be constant.
Old Nov 27, 2009 | 10:17 AM
It can sometimes only be after a cold start up or all the time.
If it is white and smells sweet, it is a head gasket, if it is blue it is oil, black is excess fuel.
Old Nov 27, 2009 | 05:17 PM
Young's Avatar
I guess its lite blue/white... so I guess that means oil...
Getting a system too lean message in banks I &II
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
Tastang
Nov 30, 2007 05:47 PM
jcostello
Nov 2, 2006 10:28 PM
