Sponsored by: CARiD
headlight switch asembly problem
Old Mar 27, 2009 | 05:43 PM
MoNtErover's Avatar
7th Gear
Default headlight switch asembly problem
My problem is when switched to the first position, eveything (including tail, parking, and dash) works, but no headlights. When switched to the second position only the headlights work. When the problem first appeared, I actually saw small wisps of electrical smoke coming from the area of the head light assembly. I am able to get all lights to work at once if I carefully turn the switch just between the 1st and 2nd position, but any little bump will cause either sets of lights to fail. Could you possibly send me a brief tutorial on how to fix or replace this part? The nearest landrover dealership is a couple hour drive. Any help would be greatly appreciated!
Old Mar 28, 2009 | 08:10 PM
angelis745's Avatar
Check the area where you first saw the smoke that's an indication of a short.
Old Mar 29, 2009 | 08:59 AM
And don't use them in the measn time, if you toast that harness, you are looking at big bucks.
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
Disco03
Dec 1, 2008 08:08 PM
pdxdisco2
Oct 21, 2007 07:47 PM
97DISCOIDAHO
Aug 23, 2006 04:08 AM
