Headlight/Wiper Switch Question
Old Aug 15, 2006 | 10:47 AM
97DISCOIDAHO's Avatar
Default Headlight/Wiper Switch Question
Hi,
I need to replace my headlight/wiper switch. I have a new switch and just need to put it in. Am I going to run into any problems where I have to unplug airbag wiring and then deal with the SRS light coming on? Should I disconnect the battery? Any input from someone who has done this would be appreciated.
Thanks,
Erick
Old Aug 15, 2006 | 11:15 AM
Default RE: Headlight/Wiper Switch Question
You will need to disconnect the battery and you have to be real careful to not damage the spiral ring. On the down side of it all, you will end up with a SRS warning light on cause of the battery disconnect and that can only be cleared with a test book or autologic scanner.
Mike
Old Aug 15, 2006 | 10:46 PM
BOOOOOOOO [:@]
That's not what I wanted to hear... but hey, I need wipers. So it looks like I'm off to my friendly stealer in Utah to have this sucker plugged in.
Oh and thanks for all your help DiscoMike! I'm in the learning process, I'll soon be replying to all these threads with my experiences. I also need to figure out how to put the signature on the bottom of my posts so I can brag about my ride... it's actually starting to become something I can claim as my own. I bought it for $2900.00 with lots of problems that I am slowly fixing. I put a old man emu set up on this weekend (heavy duty front and back). Big O BigFoot tires 245/65/16 and I'm going to be doing the hood blackout decal soon. I love this thing!!
Erick
Old Aug 15, 2006 | 11:19 PM
Stay in touch,
Mike
Old Aug 16, 2006 | 12:06 AM
Bait's Avatar
ORIGINAL: Disco Mike
Mike
Mike, Huh? Are you saying that disconnecting the battery will cause the SRS light to come on?
Old Aug 16, 2006 | 11:20 AM
Yes, it can come thru as a low voltage fault.
Mike
Old Aug 23, 2006 | 04:08 AM
Well, I replaced the switch this morning. I disconnected the battery before I started anything. I got the steering wheel out and switch replaced without damaging the spiral ring. Good news is... no SRS light! YAY!!
Here's a question... can I buy little replacement LED's that go in the ignition switch etc. The ones I have are broken.
camgkh
Jan 18, 2015 11:42 AM
AlbatrossPNW
Dec 23, 2013 12:09 PM
lrjon
Mar 14, 2012 10:00 PM
Disco03
Dec 1, 2008 08:08 PM
pdxdisco2
Oct 21, 2007 07:47 PM
