Sponsored by: CARiD
Heated rear window relay
Old Dec 28, 2007 | 10:20 AM
dcox's Avatar
Default Heated rear window relay
Anybody know where the heated rear window relay is on a 99 disco II. Wiring diagram says passenger compt fuse box. Only four relays in there and none are correct. Is it built into the fuse box like the IDM????
Old Dec 28, 2007 | 10:23 AM
Default RE: Heated rear window relay
Have you checked the relays in the box behind the battery?
Old Dec 28, 2007 | 10:48 AM
dcox's Avatar
Yes, the relay for the front is in there but not for the rear. The more I look at the diagram, I bet it is an integral part of the fuse box like the IDM. If you look at the diagram for the front relay, it shows all the pin #s, (30, 87, 85 and 86), When you look at the diagram for the rear it does not show those.
Old Dec 29, 2007 | 12:24 PM
raid13's Avatar
it seems to be internal to the passenger compartment fuse box controled by the idm
first link #6 50amp fuse in enging fuse box. then fuse 8 then relay then
output from fuse box on connector 582pin2 wire brown with purple tracer
than a splice point (a19,a167) after that connector. then connector 485-3/480-3 and then
connector 380-1 at the heater element.
ps idm stands for intelligent driver module
and yes its internal to passenger fuse box
all the best
bleizit
Jun 24, 2020 04:03 AM
RicketyTick
Jun 24, 2014 06:58 PM
RSPTex
Nov 17, 2013 11:18 AM
s10lowrider1994
Oct 6, 2011 01:22 AM
commanda
May 18, 2007 11:51 AM
