Sponsored by: CARiD
Hellllp! Coolant leaking from beneath my expansion tank....passenger side
Old Feb 21, 2016 | 10:50 PM
MysteeklRover's Avatar
Default Hellllp! Coolant leaking from beneath my expansion tank....passenger side
I just bought a used 02 land rover disco 2 series 7 a week or so ago....no leaks, had a huge amount of snow here and it ran like a champ, like I knew it would... Felt good about the purchase.. ..went to get oil change which was to include an air filter check.... tech came out said he screwed up and thought he pulled wrong cap and drained atf....they took it to another shop they said the cap wasn't to the atf ( they didn't say what it was to-i will be calling them in the mornin, BTW) and they did go on and check it and it was OK..the transmission fluid that is....so next day, noticed it was leaking coolant... Topped it off and drove ten mules, pulled in driveway and it allllll drained out..WTH???!!!
Old Feb 22, 2016 | 06:58 AM
mollusc's Avatar
First thing I'd be doing is finding out what the first place drained and what fluid they put back in, as well as where they put it. If they thought they drained ATF and therefore filled up with ATF, but put ATF where it wasn't supposed to go, you could end up with serious mechanical damage.
Then try to identify where the coolant leak came from -- burst hose, slipped hose clamp, etc. Possibly something seriously overheated because of improper lubrication and caused the coolant to boil.
Old Feb 22, 2016 | 07:48 AM
4x4 Brad's Avatar
Oh jeez. Sounds like an awfully inexperienced mechanic or garage you took it to. Sorry this happened to you.
I'd be fuming!!! Find out what's going on. Take lots of pics of the damage / scene. Be prepared to raise hell.
Old Feb 22, 2016 | 07:51 AM
drowssap's Avatar
failing recover tank is quite common on d2's
Old Feb 24, 2016 | 05:15 AM
loanrangie's Avatar
Air filter check ? , if its dirty just replace it, not rocket science but doesnt sound like they know anything about mechanicals at all.
Nothing complicated about a Rover V8, i'd hate to see them with a TD5.
Coolant tanks split in both D1 and D2 and should be replaced if condition is unknown or even slightly suspect.
Old Feb 24, 2016 | 08:39 AM
Default Fixed the problem!
Thank u all, but it wasn't their fault after all. I will never again go to Walmart for an oil change for the Rover, though....also, it was my expansion tank, but I applied a sealant and fixed the problem temporarily until I can get a tank... They sent it to a garage nearby that verified that it was NOT ATF that leaked out....he wasn't on duty so he couldn't say what he loosened, however the automotive manager looked it over and a tech who DEFINITELY made me feel he knew his stuff looked it over and the radiator isn't leaking, no visible hose is leaking but if u put your hand under the tank, u get nothing but coolant on your hands
ewatk
Jul 9, 2020 05:17 PM
MysteeklRover
Feb 24, 2016 03:35 PM
aguison
Nov 16, 2012 09:29 AM
aarongregor
Nov 17, 2011 12:27 PM
