Help
I am going to assume this is a DII.
I am also assuming that you tried using the key in the door.
I am also assuming you super locked the truck because if you didn't (and this proves why you never should use super lock) you could open the truck with the key.
You need to run a battery charger or a jumper cable to the positive battery cable on the starter, this should supply enough power to the system to allow you to unlock the doors.
alti
03-13-2013 08:30 AM
Speed racer
10-11-2008 10:56 PM
