Sponsored by: CARiD
help changing transfer fliud
Old Jul 28, 2009 | 03:44 PM
angusm23's Avatar
5th Gear
Default help changing transfer fliud
my 01 disco stated making a whining noise about 500 miles ago. it has 133k. couldent figure it out but because it is always making strange noises i let it go. now at high speeds it starts to shudder when i give it gas and stops when i let up on the gas. i changed the front dif and nothing changed. i think i need to change the transfer case fluid. any tips would be great. thanks angus.
Old Jul 28, 2009 | 06:01 PM
hilltoppersx's Avatar
have you had the front drive shaft rebuilt?
Old Jul 29, 2009 | 07:11 AM
angusm23's Avatar
5th Gear
Default tranfer box help.
no. i bought the disco in nov and have put about 15k on it. the dif fliud that i changed was milky. also the dif lock light sometimes flickers.
Old Jul 29, 2009 | 08:16 AM
One thing you need to learn real quick, if you have a problem with your truck, you deal with it today not 500 miles later. You probably have set yourself up for a big expense.
How mechanical are you, if not very knowledgable then get your truck to a mechanic ASAP.
Old Jul 29, 2009 | 09:00 AM
the milky look is water mixed with the oil in the dif unit. that means there is a way for water to get in and it was submerged in water. not good either way you need some work done to fix the dif units.
Old Jul 29, 2009 | 09:14 AM
You might want to send me your tele number, you may have a few issues.
Old Jul 30, 2009 | 06:29 AM
angusm23's Avatar
5th Gear
Default transfer fluid
i know not to keep driving but i couldnt figure the sound out and because this disco is musical in its sounds i let it go. probably a big mistake. my phone is 214 794 5372. any info on my options or what i should do next would be greatly appreciated. thanks angus.
sdhow
Oct 16, 2014 06:31 AM
amvauto
Sep 18, 2008 07:38 PM
discoboyd
Nov 24, 2007 09:13 AM
4x4master
Jun 3, 2006 11:54 PM
arocena409
Sep 24, 2005 06:26 PM
