help girl here..lol
Guys I just replaced the Hitachi compressor with the SAME Hitachi model compressor on my 2006 LR3 v6
part# K04L-L136-34SP
Miessler Automotive Air Suspension Compressor and new relay.
I thought it would be a plug and play and instead its giving me code:
C1A36 = Exhaust Valve
I was told by local shop that the LR3 needs a software update by Dealer only based on that code...
any thoughts?
closest dealer is over 1 hour away and the car is sitting high in the rear and low in the front with red susp. warning light on so I would have to get it towed! any suggestion on what to check or how to fix it?
Cheers
any thoughts?
Cheers
That code can come from putting an AMK in place of a Hitachi and not updating to the AMK software.
If you've still got a Hitachi, I would wonder if that code is from something not being done correctly. Perhaps the key was on when the compressor was removed, and so the computer stored a code? Does the code come back immediately when you clear it?
Is the compressor new or rebuilt? Either way, perhaps it actually has a bad exhaust valve. There was an issue with Hitachi compressor exhaust valves and there were kits to update them.
There is updated Hitachi software but I'm afraid that a trip to the dealer might just uncover that you've got a bad compressor.
