Sponsored by: CARiD
Hit and run: Land rover guru needed
Old Sep 25, 2017 | 11:03 AM
tyguidry's Avatar
Default Hit and run: Land rover guru needed
saturday evening my sisters car was involved in a hit and run which will likely total her car.
Looking for any information on what model/generation land rover would carry this style/pattern of headlight.
Left behind were pieces of a "Land Rover" badged headlight plastics. Based on the pattern it looks to me to be from a discovery 2? but honestly not sure. below are attached photos of said headlight pieces. this will likely be driver side housing.
Incident happened in the US so this should likely be a model that was widely sold in the states.
any/all help is GREATLY appreciated.
the info i gather here will likely be what I use to call the areas auto body/part shops.
THANK YOU.
Attached Thumbnails Hit and run: Land rover guru needed-img_1939.jpg.jpg   Hit and run: Land rover guru needed-20170924_154208-1.jpg.jpeg   Hit and run: Land rover guru needed-l17-p10151.png.png
Old Sep 25, 2017 | 12:35 PM
The D1, D2 RRC and P38 Range Rover all had a orange turn lens
Old Sep 25, 2017 | 12:38 PM
tyguidry's Avatar
Would the range rover turn signal have the "land rover" badge in the plastics like the attached photo?
Old Sep 25, 2017 | 12:39 PM
xsramo's Avatar
It could be a Discovery I or II. Earlier Range Rovers of that era (late 90's early 00's) used a similar looking and located turn signal housing as well so I wouldn't discount them. The Land Rover logo on my Disco II's turn signals are on the upper corner closer to the grill if you are facing them. Which would reinforce the idea that the drivers side on the LR would have impacted the car. Depending where you are, there aren't too many Land Rovers of that era on the road especially if you live in an area where cars are prone to rust. I am by no means an expert on this kind of stuff so take it for what it's worth. As you mentioned it'd be good to alert the local body shops to keep an eye out for a LR with driver side front end damage. Best of luck.
Old Sep 25, 2017 | 01:28 PM
Geo's Avatar
Geo
Looks a lot like the Disco 2 in this eBay listing: 00 01 02 03 Land Rover Discovery 2 Left/Drivers Front Turn Signal Light | eBay
Disco I has the logo at the bottom based on another eBay image....
Old Sep 25, 2017 | 03:35 PM
RedRovin''s Avatar
My D1 has the logo on bottom inside corner. My D2 lights don't have the logo at all...
Old Sep 25, 2017 | 04:08 PM
Geo's Avatar
Geo
Any paint transfer on your sister's car? or Painted parts on the ground? Could help determine year. Is that other piece in the bag painted? May be the part under the light and above the bumper.
Old Sep 25, 2017 | 05:14 PM
RedRovin''s Avatar
Oh! Is that clear piece plastic or glass? If it came from the headlight then you've narrowed it down to 99-02 (glass) or 03-04 (plastic).
Old Sep 25, 2017 | 06:03 PM
tyguidry's Avatar
GOOD TO KNOW!!
but which clear piece are you referring to?
Old Sep 25, 2017 | 06:05 PM
mollusc's Avatar
There is a clear piece in the second picture, in the bag with the other parts.
