Sponsored by: CARiD
Holy Crap. Sombody Help me!
Old Feb 18, 2008 | 09:05 PM
rick.scott's Avatar
Default Holy Crap. Sombody Help me!
Ok here goes:
2000 Disco II 135k
3 Amigos
Check Engine Light (Blinking)
Loose Passenger Mirror
Off Track Driver's Window (Loud Noise)
Passenger Door Lock Doesn't lock remotely
Decreased Power
All in 1 month. Help me before I hang myself.
Old Feb 19, 2008 | 10:22 AM
Default RE: Holy Crap. Sombody Help me!
So, what have you done about it so far? I would suggest till you get the check engine light issues resolved, yoiu not drive it.
Old Feb 21, 2008 | 10:38 AM
cold_surfer's Avatar
Off Track Driver's Window (Loud Noise) - $35 track at britishatlantic.com rover parts (MUC2322 door window lift channel front) OR it's possibly the regulator. If your door is RUSTY I would guess the channel is broken. I saw a new regulator on ebay for about $50 -- that is the "scicsors/gear" contraption. wear some gloves when you start digging into the door with your hands. Remove the door panel, peel back the plastic, and take a look with the flashlight. I just ordered a new channel for my 93 RRC (same unit) passenger door yesterday that was getting brackish salt-water sprinkler spray down into the door for a few years -- it rotted out the channel but the regulator was still good. 10mm socket, 4 bolts to remove the regulator. push the window to the TOP and jam something rubber to wedge/hold the window up. when you install
Passenger Door Lock Doesn't lock remotely - probably needs lube -- pop off the door panel and spray some liquid wrench on the linkage points and then follow up with white lithium grease.
Decreased Power - I would start in this order: replace air filter, add some fuel injector cleaner, look for disconnected/cracked/off vacuum lines, change the fuel filter, clean the MAF (search other post), replace o2 sensors, check that the vacuum advnace on the distrib holds vacuum, plugged cats?
is it overheating? is gas mileage higher than normal? stalling out? something stuck in the air intake (leaves, bird nest, etc...).
Good luck.
Old Feb 22, 2008 | 09:21 PM
rick.scott's Avatar
Thank you very much fellas. Ihave not driven it since the posting. I will try to work on it this weekend
Old Feb 23, 2008 | 08:48 AM
For as slow as your response was, next time don't be so dermatic with your post topic.
Nov15
Jul 23, 2015 06:27 AM
dieselmissfire
Feb 13, 2015 01:11 PM
gribur
Feb 8, 2014 08:14 PM
calebbo
Jan 31, 2014 06:16 PM
glassman66
Jul 7, 2012 03:10 PM
