Sponsored by: CARiD
Hose clamps
Old Nov 22, 2014 | 08:11 PM
Drubie22's Avatar
Default Hose clamps
I know this is a noob question but anybody know how to loosen these clamps? All three hoses are leaking coolant at the T and I need to swap them out.
Old Nov 22, 2014 | 08:52 PM
drowssap's Avatar
you can get them off by placing a small screw driver blade under the hasp, but they can not be reused. you will need to replace them with screw type
Old Nov 23, 2014 | 09:29 PM
Drubie22's Avatar
Is it possible to stop the leaking just by replacing the clamps or do I need new hoses and T?
Old Nov 23, 2014 | 10:03 PM
lordmorpheus's Avatar
How many miles are on the vehicle? That hose is sold as a single unit, tee and all. You may be able to get by for a bit by shortening the hoses if the ends are weakened, and re-clamping them onto the tee, but it's generally recommended to replace the entire hose.
When my upper hose began leaking 5 years ago at 110k miles, I replaced every single piece of hose and plastic tubing on mine because I knew they were all the same age.
Old Nov 24, 2014 | 07:45 AM
drowssap's Avatar
i dont see why you could not replace it with a good stainless screw clamp
humroot
Sep 28, 2019 11:07 PM
photocrimes
Mar 9, 2011 12:12 AM
jwfuller
Sep 29, 2007 11:53 AM
werldcup
Mar 14, 2007 05:05 PM
jstreet
Dec 16, 2006 07:44 PM
