Sponsored by: CARiD
HOT Engine compartment
Old Jun 12, 2007 | 10:19 PM
dalfier's Avatar
Default HOT Engine compartment
I just purchased a 99 Range Rover 4.6 HSE. I had to drive about 70 miles home and everything went fine. I have had it parked for about 3 hours and the engine compartment still seems to be hotter that one would expect. Is this normal?
Old Jun 13, 2007 | 08:29 AM
Default RE: HOT Engine compartment
If you are not getting any indications of the engine running hot per the temp guage, what you are notcing is probably normal.
Mike
Old Jun 13, 2007 | 09:19 PM
dave1070's Avatar
8th Gear
I've had my 1996 discovery for about two months now and it does seem to run at a much higher temp than other eights ive had,and also hold the temp longer but it is still running strong so at this point i'd have to say it is normal.
Old Jun 13, 2007 | 09:51 PM
MadBilly's Avatar
There is a reason that is like that. It is an aluminium block engine, not iron. Iron would hold that heat, aluminum dissapates heat into the engine compartment. Basic physics at work here.
Xrover
Jun 2, 2024 05:14 AM
ngarover
Dec 5, 2010 08:54 AM
RoverRover1
Jun 1, 2009 09:37 AM
luxury1
Apr 26, 2009 08:39 PM
bigugly82
Dec 31, 2006 03:13 AM
