Sponsored by: CARiD
How can I get 35" tires on a 2004 Disco!
Old Oct 26, 2008 | 01:02 PM
hazletbassist89's Avatar
Default RE: How can I get 35" tires on a 2004 Disco!
I'd say 32s but it's really up for debate to be honest. It really depends on a lot of different factors. You really want to go big don't you?
Old Oct 26, 2008 | 02:04 PM
Yes, 32's, like a 265/75/16 will work for medium duty wheeling but eventially you will need to address the spider gear wear.
Old Oct 26, 2008 | 02:27 PM
RealRitzcracker's Avatar
How much do spider gears cost???
I should be able to get 34's on this bitch with a 2inch lift!
34's arn't that Big.
Old Oct 26, 2008 | 03:02 PM
32's require a 2" suspension lift probably brake lines if you don't want to ruin yours, 34's will require MUCH more. You'll need about 4" of lift, brake lines, new drive shafts, new spider gears as mentioned, and a few other things as well.
Old Oct 26, 2008 | 03:32 PM
It is not just the gears, you would need locker that have 4 spider gears for more strength, instead of the stock smaller 2 spider gear factory set up.
Old Oct 26, 2008 | 07:18 PM
Damn!
I've see 35's in person they arn't that big!
Ok so 35's out of the picture.
I just want to know the largest tire I can get with a 2" suspension lift.
Old Oct 26, 2008 | 07:36 PM
32 inch tires would be the biggest. That's 265/75/16 or 235/85/16.
Old Oct 26, 2008 | 07:38 PM
Which would be better for off-roading.
265/75/16 or 235/85/16?
Old Oct 26, 2008 | 08:01 PM
The fatter 265s are better for thick mud and snow, but the thinner 235s will give you better grip on rocks and in water crossings and stuff. I'm going with 235/85s after my lift even though I do more mud than rocks because I think the difference is negligible, and the thinner tire will stuff up into the wheel well better.
Old Oct 26, 2008 | 08:19 PM
Well where I live there isn't any big rocks and boulders.
Pretty much there is two things MUD and MUD.
So I was thinking the thick.
Now I don't have to get any new axles or gears with 32's right???
