How do you reset ol change indicator?
changed my own oil/filter but still get the -5000 miles OIL indicator message on my LED every time i start up.
'08 RR HSE
anyone know how to reset this status indicator? can i?
THANKS!!!
'08 RR HSE
THANKS!!!
Try this out, it might work. These are the steps used for a 2003-2004 HSE model.
Resetting the Oil Service or Service Interval Message.
Ignition key must be "off".
* Press and hold the try odometer button in the instrument cluster (left button) and turn the ignition key to the first position (KLR).
*Keep the button pressed for apprx. 5 sconds until one of the following words appear in the display: "OIL SERVICE, or "INSPECTION, with "reset".
* Released the reset button and press and hold it again until "reset" begins to flash.
* After the display has shown the new interval, the following will appear: "END SIA".
If you do it right, the numbers should start counting down backwards for, in order for your next oil change to take place. Good luck man. Keep on Rovin.
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
Dan_da_LR3_H2_man
May 28, 2009 11:37 AM
