how to reset check engine light
Old 11-22-2016, 08:56 PM
dqdave1's Avatar
Default how to reset check engine light
2005 freelander se; had a coil go bad; replaced it; now how to reset to make check engine light turn off
Old 11-22-2016, 09:13 PM
landlover_1's Avatar
Oooo.. this is an easy one - I may be able to handle it
Sometimes if I sweet talk my Rover while driving down the road things get better…. not always but sometimes...
Otherwise, if you're desperate, you can go to Autozone or an auto parts store, borrow their Ultragauge and reset the codes yourself. It’s not hard – just a lot of button pushing and more sweet talking
Autozone is always good fun. They loan out all sorts of interesting objects. Try it - I love that place!
Old 11-23-2016, 10:41 AM
abran's Avatar
If you don't like to sweet talk your rover, and hate autozone because their jingle makes you want to "Get into the zone", you can try a hard reset. Doesn't always work, but sometimes.
Remove cables from battery, jump a cable from positive to negative cable, being careful not to touch the battery and leave it there for 10 min. This should discharge all the capacitors and erase the CEL.... Should.
Old 11-23-2016, 03:21 PM
Sweet talking is a lot more fun than electro-shock therapy...
Old 11-24-2016, 09:28 AM
abran's Avatar
Depends how you do it...
Old 11-24-2016, 10:14 AM
or who's doing it...
Happy Thanksgiving!
Old 11-24-2016, 12:09 PM
abran's Avatar
Happy Thanksgiving!
so true.
vous aussi!
Old 11-26-2016, 07:23 PM
dqdave1's Avatar
Well; went to advance auto, they said, no problem, but when they hooked it up, it said # 5 misfire still and also now a #1 misfire; what do you guys think?
To clarify; the service engine soon light is on, not sevice engine light.
Old 11-27-2016, 09:14 AM
abran's Avatar
I've never owned or worked on a Freelander.
is it a coil pack or individual could on each plug?
if individual, change a misfiring coil to a non misfiring location. If it follows it's the coil. If not it's either clogged injector or plug.
Old 10-25-2017, 03:14 PM
dcass0409's Avatar
I said I needed to reset my LR2. Land Rover check engine light.Thanks
Quick Reply: how to reset check engine light
