How to unarm the alarm with out the remote?
Do LR alarm system have a push-switch to disarm the alarm? I am comparing it with some after market alarms were the installer mounts a push botton to de-activate the alarm incase of a lost remote.
My Disco's alarm is acting-up and sometimes it activates by itself... my new remote is not programed yet.
Thanks
Thanks
RE: How to unarm the alarm with out the remote?
ORIGINAL: Disco Mike
Ed, Rovers can disarm the alarm with the key or the remote, there are no hidden switches from the factory.
Are you having a problem with your's?
Mike
Mike
And to answer your question, yes... my alarm activates by itself off and on and at random times. It has not worked for ~5 months but two weeks ago it started showing me again who is the boss!! I have posted questions and i have checked the switch on the hood, I checked the module connections, I was told Disco I does not have a spider, I checked the grounds and still... it has a mind of its own.
Cheers
ORIGINAL: BMWLR
Your post was not clear to me... hmm... is this like turning on and off the ignition switch on a specific sequence?
Thanks
ORIGINAL: Spyderman
...by entering the code using turns in each direction using the key in the ignition.
Thanks
ORIGINAL: Spyderman
That's right, exactly as you describe. How to do it is described in the owners manual and the code should have been supplied to you in documentation.
I'm not the first owner so I was not supplied with doumentation on such code. The previous owner confirmed not having knowledge of the code. I guess if this is true on Disco I, I would have to go to the dealership with my title and DL... but my nearest LR dealership is after 2 hour drive. Does any one on this forum work at the dealership
bcolins
12-08-2013 09:17 PM
RROJ
10-09-2010 07:39 AM
RROJ
10-08-2010 09:56 PM
phuzzzed
02-06-2007 11:37 PM
